How to Use AirPlay on Fire TV: Easy Guide Needed
Hi everyone,
I’m trying to figure out how to use AirPlay with my Fire TV. I’m not very tech-savvy, so I could use some simple instructions. Does anyone know how to set it up or if I need a special app? Any help would be greatly appreciated!
Thanks!
To use AirPlay with your Fire TV, download the AirScreen app from the Fire TV app store and follow the setup instructions. Ensure your iPhone and Fire TV are on the same Wi-Fi network, then open the Control Center on your iPhone, tap “Screen Mirroring,” and select your Fire TV from the list.
Alternatively, you can use the DoCast app https://apps.apple.com/us/app/screen-mirror-smart-tv-docast/id6446948344 which doesn’t require installation on the Fire TV - just download it on your iPhone and start mirroring.
To use AirPlay with your Fire TV, you can try apps like ApowerMirror, AirBeamTV, or DoCast. ApowerMirror requires installation on both your iPhone and Fire TV for easy screen mirroring. AirBeamTV and DoCast don’t require installation on the Fire TV - just download the app on your iPhone and follow the instructions to start mirroring. Ensure both devices are on the same Wi-Fi network, and follow the app’s setup steps for a hassle-free experience.
