I’m trying to figure out how to screen mirror my phone or laptop to my LG smart TV. I’ve tried a few things but haven’t had much luck so far. My TV is fairly new, so I’m sure it has the capability, but I’m not sure if I’m missing something in the settings or if I need to use a specific app.
Has anyone successfully done this and can walk me through the process? Any help would be greatly appreciated!
For LG TVs that don’t support AirPlay, you can use an app like “DoCast” or “ApowerMirror” to cast your screen. These apps work over Wi-Fi and are pretty straightforward to set up. Just install the app on your phone and follow the instructions to connect.
To screen mirror on an LG Smart TV, the DoCast app is a good option, offering easy setup and compatibility, though some users face occasional lag. LG Screen Share is built-in and works seamlessly with Android devices and Windows laptops but may not support iPhones natively. AirPlay is another option if your LG TV supports it, providing high-quality mirroring for Apple devices. Check your TV’s settings for compatibility.
