How to screen mirror from iPhone to Sony TV?
I want to screen mirror iPhone to Sony TV to play games, but when I try using the Control Center, my TV doesn’t show up on my iPhone. Both devices are connected to the same Wi-Fi network. I’m not sure if I need a specific app or setting on my TV to make this work. Can anyone help me figure this out?
Screen mirroring from an iPhone to a Sony TV can be challenging, especially if your TV doesn’t support AirPlay directly. First, check if your Sony TV is compatible with AirPlay by going to the TV’s settings and looking for AirPlay options. If your TV doesn’t support AirPlay, or if it’s still not working, you can use an app like DoCast
It’s designed specifically to mirror your iPhone screen to TVs without built-in AirPlay, and it’s simple to set up. This should let you play your iPhone games on the big screen without any problems.
Since you want to play games from your iPhone on your Sony TV, it’s important to have a smooth and responsive connection. If AirPlay isn’t supported or isn’t working, you can try using apps like DoCast or Replica. Both of these apps work well with Sony TVs and can help you mirror your iPhone screen for gaming or other activities. Just make sure your iPhone and TV are on the same Wi-Fi network.
If you’re still experiencing issues or want a more stable connection, using an HDMI adapter to directly connect your iPhone to the TV is another great option. This method provides the best performance with no lag, which is ideal for gaming. It’s a solid alternative if wireless options aren’t giving you the results you need.
